SOURCE: MESSAGE DISPLAY H98
The H98 fault on a Panasonic can be a bad magnetron, inverter or control panel.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: panasonic microwave 1250w shows H98 on the screen
the only thing you can do is contact the service center 1 800 211 7262
SOURCE: microwave will not work...display reads H98
H95, H97, H98 or
H99 mean that there's a problem with your inverter,
magnetron, or digital programming circuit.
It may be a loose connection in the wiring between the
inverter, magnetron, and/or control board, or maybe one of
those
components has failed.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
SOURCE: What does H98 mean on the display of the microwave
H95, H97, H98 or
Due to the lethal
We're
i don't know. consider pulling the plug then plug it back in. the program may reset.
THIS IS ANSWER FROM 2008
""SOURCE: MESSAGE DISPLAY H98
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here. ETC...............""
