Three phase
three phase power = 1.5Kw
single phase = 1.5KW/3
500w
kw = 500w/.86 (.86 is power factor)
kva = 581.39 watts
current = kva / voltage
voltage = ? 120 v at guess
current = 581.39 / 120
current one phase = 4.84 amp
three phase = 4.84 x 3
14.53 amps
http://myelectrical.com/notes/entryid/8/three-phase-power-simple-calculations
240v would come out as 7.26 amps
SOURCE: My Grundfos JPS4 1 HP Pressure Booster Pump keeps coming on for a
Definately sounds like a leak in the pipes from the pressure side of the pump onwards, even the smallest leak will cause it to turn on to regain adequate pressure.
SOURCE: grundfos mq3-45 pressure booster pump
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
SOURCE: hi, i have installed a
here you can find the solution http://www.plumbnation.co.uk/site/grundfos-upa-15-90-home-booster-pump/Grundfos%20UPA%20Technical%20Information.pdf
SOURCE: Grundfos pump switches on & off continuously with
if you have a pump for the whole house you need to check the bladder tank. there is a air valve on the top. Check the pressure with a tire gauge you should have at least 20 PSI this will stop the pump from the on and off thing.
You can compress air yuo can not compress water. thats why the ballder tank. As the pump work to shut off pressure it is compressing air. then when you use a little water the pump does not run until a large about is run then the pump will re fill the system
Best of luck
R J
SOURCE: where can I get a new capacitor for a grundfos mq3-45 pressure booster pump
Hi try a internet search for farnell they are world wide
Testimonial: "did a search for farnell and while looking up information on them found a company close by that sells capacitors. Thanks for your help!"
