e
emmanuel makuvaro Posted on May 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ir3035 cassette 1 paper sensor not responding
edy copier
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Canon Expert 306 Answers
  • Posted on May 03, 2018
edy copier
Canon Expert
Level 2:
Mentor:
Answers
306
Questions
Helped
68195
Points
729
There is dirty selenoid of paperbang, change the foam on selenoid with seal tape.
1helpful
Error 501, 502, 503 & SC441
Error codes 501, 502, and 503 on a Ricoh MP-8001 indicate a problem with the paper cassettes. SC441 is a drum motor error code. Here are some steps you can take to troubleshoot these issues:
  1. Check the paper cassettes: Make sure that the paper cassettes are properly loaded and that the paper is not jammed. Check that the paper guides are set correctly for the paper size.
  2. Reset the paper cassettes: Open the paper cassettes, remove the paper, and then close the cassettes again. This may reset the paper cassette sensors.
  3. Check the drum motor: SC441 is a drum motor error code. This may indicate a problem with the drum motor or the drum unit itself. Check the drum unit and make sure that it is properly installed.
  4. Check the front door sensor: If the front door open sign is appearing on the screen even though the door is closed, there may be a problem with the front door sensor. Check the sensor and make sure that it is properly installed and functioning correctly.
If these steps do not resolve the issue, it may be best to contact a qualified technician for further assistance. They will have the expertise and equipment necessary to diagnose and repair the problem.
1helpful
3answers
Canon image runner ir 2520 says load paper but the paper is already on the paper tray please help
Cassette sensor switch inside the machine body. Remove cassette outside and check machine body bottom where cassette is installed. Switch Has been misalignment by unfortunately. Align this two Switch Sensor Then again install cassette. Hope its working.....
2answers
Show me a picture of the waster toner on canon ir3035
It's in the front of the machine,abowe the paper casette.Part number for the waste toner box is FM2- 0303-000
How to sole Canon IR 1600 check printer cover error
(1)
If one of the doors on the Cassette Pedestal is open, then the main unit will display the 'check printer cover' message. Check to make certain all of the doors on the Cassette Pedestal are completely closed.
Note: These doors are located on the lower left side.
(2)
In service mode: (DORSW1/DORSW2) tested good.
Solution :
It may be necessary to refit the vertical path guide for cassette if it was not hitting the retry sensor, PS152, in the cassette unit.
Note that every cassette has a retry sensor (PS152).
(3)
Paper is "crunched" into the Retry sensor.
3helpful
2answers
Canon IR3035 E000024-0001: paper jams every after a copy
check the jam position, the sensor arm there must not be returning to norml position after first copy.
1helpful
My 2270 jambs paper from tray one every time. I changed the pickup rollers still no help. All my other trays feed properly even the stack bypass
Hi mate,
Prior to your issue i may enlighten you with this source.
Technical Infomation 0105/0101/0102/0103/0201/0202/0203/0204 Jam Code: Paper lint adheres to surface of vertical path roller
Description
Since a type of paper that can easily generate lint was used, the paper lint adhered to the surface of the vertical path roller and decreased the paper feed performance of the roller, causing the jam code "0105."
Depending on paper sources, the following jams occur.
- Cassette 1: 0105 (registration sensor PS9 delay)/0201(cassette1 retry sensor PS10 stationary)
- Cassette 2: 0101 (cassette 1 retry sensor PS10 delay)/0202(cassette 2 retry sensor PS11 (cassette pedestal) delay)
- Cassette 3: 0102 (cassette 2 retry sensor PS11 delay)/0203 (cassette 3 retry sensor PS1 (cassette pedestal) delay)
- Cassette 4: 0103 (cassette 3 retry sensor PS1 (cassette pedestal) delay)/0204 (cassette 4 retry sensor PS2 (cassette pedestal) delay jam)
To prevent this, a vertical path roller to which paper is hart do adhere was used for the following machines (the color of the roller was changed from black to gray).
- iR2230 120V THF03592 and later/120V TW SHD00033 and later /220V CN SHC01553 and later/230V EUR THG02606 and later /230V THH00339 and later
- iR2270 120V SLH28893 and later/120V TW KJN00097 and later/ 220V CN KJL00763 and later/230V EUR KGL54733 and later/230V KGM03613 and later/230V CA SLF02281 and later
- iR2830 120V THK01045 and later/220V CN SHE01035 and later
- iR2870 120V SLG13303 and later/120V TW KJR00054 and later/220V CN KJP00589 and later/230V EUR KGD13135 and later/230V KGE00333 and late/230V CA SLD00411 and later
- iR3530 120V THL01319 and later/120V TW SHK00085 and later/220V CN SHH00829 and later/230V EUR THM01596 and later/230V THN00209 and later
- iR3570 120V SKV61037 and later/120V TW KJU00760 and later/220V CN KJS00928 and later/230V EUR KFW21901 and later/230V KFX02555 and later/230V CA SKT01761 and later
- iR4570 120V SKU23728 and later/120V TW KJX00122 and later/220V CN KJV00690 and later/230V EUR KFQ15439 and later/230V KFR02186 and later/230V CA SKQ01030 and later Field Remedy
When the symptom occurs with the machine without the foregoing serial numbers, replace the vertical path roller.
Kindly rate me !!!!!!!!thank mate.
Feed switch unresponsive
your case seems the cassette feed unit can not detected by cassette unit sensor which locate around the paper input roller area.you need to check
1) the cassette push in the well position which can touch the sensor well egnough
2) find out this sensor and adjust the sensor sdander position (more sensitive).
2answers
HP design jet 450C inkjet Media Error`
Clean the Paper sensor which is down button use to feed the paper & the paper edge sensor on the carriage unit
Brother mfc 8600
Hi, For those models available with a 2nd paper cassette, the "Check Cassette#2" will appear if the 2nd cassette sensor does not detect the paper cassette. So my thinking is that 1: the cassette is not seated in the printer correctly (not trying to be insulting, but it can happen to anyone) or 2: the sensor that "sees" the cassette is either out of place, or it has dust blocking it. (It could also mean that the sensor itself is bad.) Good Luck.
old marine
old marine
ZJ Limited
ZJ Limited
