Question about Refrigerators
Door alarm on freezer part of fridge won't stop. How can I turn it off until I get a. Repairman in the morning. I can't move the fridge out to get to the back. Thanks.
  • Refrigerators Master
  • 4,057 Answers
Clean the rubber seal around the door frame the alarm is that its not keeping its temperature, its not sealing round the door frame properly.
Posted on May 02, 2018
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: I have a Fisher and Pykel Fridge / freezer Active Smart
on reading the user manuals, it suggests actually calling the F&P customer service numbers and telling them the pattern of the lights flashing.
They can ?diagnose the fault from the light sequence and can then tell you what u need to have fixed.
Posted on Jan 08, 2008
Anonymous
  • 42 Answers
SOURCE: uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on Mar 29, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Posted on Jul 02, 2009
rosscof
SOURCE: when fridge/freezer door is opened the fridge
WHEN i OPEN MY WHIRLPOOL FRIDGE THE LIGHT FLASHES ON AND OFF AND THE COMPRESSOR APPEARS TO CUT IN AND OUT AND THE FRIDGE BEEPS UNTIL DOOR IS CLOSED. cAN ANYONE HELP?
Posted on Oct 25, 2010
W.L.
  • 2509 Answers
SOURCE: Door open alarm sounds and door open indicator
The switch which detects whether the door is open may be malfunctioning or the control unit to which the switch is connected is faulty. If there is only one switch it may be the same switch which puts the light on as you open the door.Does the light come on when the door is open? If so the switch if there is only one, is probably ok but the control unit is faulty.Look around the edge of the door frame for switches and check they are not stuck or damaged. I hope I have been of help but please do not hesitate to ask if you have any further questions.
Posted on Feb 20, 2011
My door alarm on Kenwood fridge/freezer beeps when I close the door and freezer temp flashes -88 before going back
Hi Both - I had this problem this week. Fridge is under warranty.
Engineer visited today and said it's the wiring loom to the door display.
On inspection part of it was worn meaning power being disconnected during opening & reconnecting on closing. The reconnecting of the power lights up the display but it looks like an error.
He's ordered a new wiring loom as he suggested fixing it doesn't work well.
Until the loom is replaced he's unplugged the door connector to stop the beeping, stop the display being turned off/on 50 times a day and reduce electrical risk.
Hope this helps - A
Jun 03, 2018 | Refrigerators
My Miele Fridge Freezer Keeps Beeping Although there is no issue, how do i remove the alarm?
I bet the light is also staying on inside even if the door is closed. There is a switch inside that turn the light on and off when the door is open. If the (Door Switch) is working then the light inside should shut off when the door is closed to save energy. It also tell the computer the door has been shut in case you forget then it will notify you. The switch may not be working. Look for a door with on ebay or sears. Need your model number and brand of the unit.
Sep 20, 2016 | Miele KFN8762SDED Bottom Freezer...
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
Hotpoint FZFM171 freezer door left open all night, has defrosted and the 'super freeze' light and alarm light wont stop flashing. How do we fix it?
Turn the power off to the refrigerator and manually defrost the freezer until the freezer bis no longer cold and then replug the power cord
.APPLIANCE 911
Jan 27, 2016 | Hotpoint Refrigerators
My Westinghouse freezer has an alarm beep that goes off every now and then and the only way to stop it is to turn off the fridge completely. In the fridge section the temperature panel flashes the...
Often these have door alarms. If the door isn't completely sealed shut then it will alarm and cause the temperature/thermostat to blink to warn of "warm" temperature inside the fridge
Mar 04, 2015 | Westinghouse Refrigerators
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
Fridge works intermittently
Some Of These Fridge Freezers If You Open The Door For The Freezer There Is A Switch Between The Fridge And Freezer Door Mine Done The Same And I Had To Replace That Switch It Turns The Fan On When Door Is Closed And Off When Open
Nov 04, 2013 | Refrigerators
Refrigerator doesn't stay on.
sounds like when you moved it you created an air lock, when moving fridges etc. should always leave for 24 hrs to settle before plugging in.... , no guarantee but try laying it down and leaving overnight then stand it up again and leave for at least 24 hrs for the refrigerant to try and sort itself out. UNPLUGGED from mains of course... good luck
May 02, 2017 | LG LFX25960ST Stainless Steel French Door...
Fridge light not shutting down, alarm on, temperature heating up
you do have a switch at the top door hinge . make the phillip screw are tight at the top of the door . if they are loose the door will not align in order make contact with that switch. or you may have a faulty light switch
Oct 20, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
