SOURCE: How to change brake light bulb on a 2014 fiat 500L
https://www.fiatusa.com/download/pdf/manuals/2014-FIAT-500L-OM-1st.pdf
it's in your owners manual page 358 chapter 7
you need a torx 20 screwdriver or bit
Rear Tail, Stop, Backup And Turn Signal Lamps
1. Open the liftgate.
2. Remove the two screws and remove the tail lamp assembly.
3. Remove the four screws (using a T20 driver) and separate the backplate from the lamp housing.
4. Remove the tail, stop, or turn signal bulbs by pushing them slightly and turning counter-clockwise.
5. Remove the backup lamp bulb by pulling straight out.
6. Replace lamps as required and reinstall lamp.
Center High-Mounted Stop Lamp (CHMSL)
This light is an LED assembly. See your authorized stealership
SOURCE: How do I remove the headrests on a fiat 500l so I can put on seat covers?
you dont,cut the cover and slide down over the headrests and sew them together
