SOURCE: ticking noise
the first [& easiest] solution is to change your PCV valve.if that dosen't make a difference,it could be valves need adjustment or a problem w/ a valve lifter.
SOURCE: strange noise coming from behind glove box
The adjustment on the linkage for a vent door,was off,and you corrected it.
SOURCE: chevy trail blazer "clicking noise" from fuse box !
It sounds as if one of your relays in your fuse box is on its way out. The contacts in a relay may have an audible clock when they engage and the click will get louder with age and wear. The relay is probably linked to the circuits you are having problems with. Find out which relay controls the items you are having problems with (refere to owners manual or check on fuse box panel, it usually tells you what they are for). If you can not locate the really by name then you can open the fuse box and put your hand over all of the relays and you will feel the one that is clicking. It will probably be hot too. I would replace this relay and your problems should go away.
SOURCE: car won't start and makes a ticking noise
CHECK IF TURN SIGNALS WORK, USUALLY ON GM CARS IF A BULB IS BURNED IT WILL TICK FASTER, IT IS AN INDUCATION OF BURNT BULB - COULD BE FRONT OR REAR
SOURCE: My Samsung LN52A550 LCD TV will not stay on.
The ticking noise usually comes from the power section of the tv. Usually it is a capacitor failing. As far as the cost of repair this can go either way ie cheap or expensive. It will dpend on what exactly has failed and if it requires a board replacement or just a part.
I'm going to assume this isn't under warrenty anymore. It is covered if it is. You need to get some repair estimates from Samsung and any tv repair shops. Then keep and eye out for a replacement. Make sure you include any shipping costs or other costs when you are totaling up the estimates. If it gets close to the replacement cost then you will have to choose if you want a new tv or have a repair done.
a list of problems and fixes for usb drives
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box
((I have found better results ticking the first box then reurn and tick the second box)) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this
click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hope this helps you
tick in two boxes automatically fix files and scan for and attempt recovery of
bad sectors place then a tick in both boxes then select check now start or you
and tick the second box then wait for that to finish
hope this helps
