SOURCE: my hitachi 50ux58b red light comes on but tv wont come on.
check diod d915
check d196
check for open fuse on the B+ side
replace c707 1000uf @ 2KV
replace IC 901 and H.O.T location Q777
hope this helps,
regards
daniel
SOURCE: wont turn on red light flashes
The error code of 2x red flashes tells me you need a Y DRIVE ASSY and
the part number is AWZ6649. It should be replaced by a Technician thou.
Hope this hleps
SOURCE: will not come on
It will be the mainboard but not 100% sure because I need a more detailed description of the sympton.
But by the look of your description if it is not fixed with a mainboard it will be the powerboard for sure.
SOURCE: tv wont turn red light is on .unplug try remote and switch on sid
Are you still having this problem?>
SOURCE: red ir light floashing and tv wont come on Onn lcd tv
red light flashing on bottom of tv and no picture
We would be happy to help you with getting your new DISH Network remote to control your TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your Orion TV; here are some of the codes we currently have for it: 720, 748, 748, and 748. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Orion TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
