SOURCE: brother Hl-2040 laser printer
Fonts and sizes are typically controlled by the application you are using. Are you sure you are increasing the font size? I've had some users confused by the zoom feature which is more like a magnifying lens. It just makes thing larger for viewing purposes and does not affect the print size. To change the actual font size of a document already created you would first highlight the text in the document. In Word (other applications are similar) you would then select Format from the main menu bar, then select Font. In the next box that appears you would click on the Font tab, and then in the Size field select a larger font size. After that click on OK and you should see your font size change. Let us know if that was your problem or not.
SOURCE: printing dots on Brother HL 4040CN
do this procedure
1.print test page then stop the printer on the middle print proses by turn the printer of or open the rear cover
2.remove the paper jam carefully
3.look to the paper if the problem found change the drum unit els the fusser unit cause the problem
SOURCE: Brother HL 5250 DN status shows "error". Won't print.
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: Difference between Brother HL-4040CN and HL-4050CDN printer
HL-4040CDN supports BR--Script (like Postscript) and
HL-4040CN does not.
So, there is a "postscript" diver for the 4040CDN, but not for the 4040CN.
SOURCE: Brother HL 1440 Laser printer-horizontal black streaks
check your drum may the corona ware is broken . change the drum.
