Question about Kenmore Freezers
I have a Kenmore Elite upright freezer model 25326072101 that will not stop running but keeps food frozen. Had a frig tech out to inspect and he said it was a the relay sensor 100% sure.
He never came back to fix or returned calls - can I get this online and have an electrician friend change it? Can't find it online when searching for the part relay sensor - is this called something else to order?
    Top Expert:
  • Kenmore Master
  • 65,304 Answers
Water Filters Lawn Garden Appliance Parts check model number here for parts
Posted on Apr 26, 2018
Testimonial: "there is no "relay sensor" on this site for this model- as I had indicated online searching does not get me to a "relay sensor" - thus wondering if "relay sensor" (ie is it within the electronic control board?) is within another part or called something else?"
  • ray gallant
    ray gallant Apr 26, 2018
    sadly I have no idea and if you had asked the tech when he was going to replace it , then it might have been done
6ya staff
SOURCE:
Ronnie Houston
  • 2920 Answers
SOURCE: Door Panel
i would go ahead and go to them let them fix it and have it back sooner.at least it will be fixed
Posted on Jan 17, 2009
Tech jk
Tech jk
  • 102 Answers
SOURCE: windshield wipers stuck upright when off
This is a commoon problem with what is called the "Park pawl stop". The tab is most likely bent and needs to be re-aligned, then the wipers need to be re-timed. This re-timing can be a little difficult, although the re-aligning of the tab is failry simple.
TechJK
Posted on Apr 18, 2009
Anonymous
SOURCE: ABS Fault? Renault Megane
Hi Liz, I am in exacty the same position as you although I just had the new abs pump fitted and I still have the same problems??? I am going crazy with this, my garage's diagnostic machine won't commuicate with my car and my speedo is not working? My mechanic reckons the abs memory is stuck in a loop and that is why the lights ain't going out, but without a diagnostic I dont know, I guess I will have to take it to a dealership to be ripped off!!!!
Tracey
Posted on Sep 26, 2009
emissionwiz
Marvin
  • 85216 Answers
SOURCE: 1998 Saturn SL2 firing order for spark plug wires.
please go to the web link for diagram and firing order. It is the correct one.
http://autorepair.about.com/library/firing_orders/bl-fo-4959.htm
Posted on May 07, 2010
Testimonial: "Thank You so so so much. I appreciate this greatly. I looked everywhere for help, and glad I found you. I am a female who is thinking that working on cars is not her forte. "
duane_wong
Duane Wong
  • 6826 Answers
SOURCE: Diagnostic of my NISSAN Altima
The crankshaft sensor is an important sensor for regulating spark and fuel injection pulsing.
I don't know what an 'engine sensor' would be besides the crankshaft sensor, specifically.
Engine sensor is a general term.
Posted on Aug 19, 2010
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
Freezer not freezing
If you can hear the motor running it could be the thermostat that has gone or if there is no noise at all it could be the motor that has died, a good easy fix ( sometimes works ) is to turn the freezer off leave it for 24 hours with no power then try turning it on again.
ThanksTalkAppliance.co.uk
Apr 22, 2012 | Kenmore Freezer 20.6 cu. ft. Upright...
My Kenmore upright freezer, serial #WB95125779, model #253.9284213, is not freezing my food? All of my frozen food was spoiled. Can anybody give me any solutions?
You may need freon, or your compressor has died. Either way you need a service guy. Sears has their own service people. It may be under warranty.
Apr 22, 2012 | Kenmore 14.1 cu. ft. / 399 liter Upright...
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Dec 03, 2008 | Kenmore Freezer 14.1 cu. ft. Upright...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore freezer not cold at all!
We had a Kenmore upright which worked fine but then suddenly was not keeping food frozen. Long story short, do not store anything on top of the freezer unit. It will insulate the coils that run across the top of the unit, and cause your compressor to work harder than it needs to, and eventually overheat and become ineffective. Says nothing about it in the user manual. We learned the hard way by losing food.
Jul 30, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezers Logo
208 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
