Dishwashers Logo
Posted on Apr 26, 2018
Hi! I have samsung dishwasher DW80H9930US. Waterwall do not moving. Motor ,vane sensor and circuit board was changed. No error code is disply.
3 Related Answers
pierre1811
Perry Putnam
  • 144 Answers
  • Posted on Jan 19, 2009
SOURCE: E6 error code displayed on Kenwood kdw243a dishwasher
The reset sequence used is:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
Anonymous
  • 617 Answers
  • Posted on Feb 18, 2010
SOURCE: 1988 Dodge Aries K 2.5L Engine Trouble and codes
CODE 14
Trouble Code 14 indicates that the Coolant Temperature Sensor (CTS) is reporting abnormally high readings. CTS is used to control fuel mixture, timing, idle speed, TCC and EGR operations among others. The thermistor used has a low resistance when hot, rising as the coolant cools. This error then, indicates a very low resistance in the CTS circuit.
CODE 15
Trouble Code 15 indicates that the Coolant Temperature Sensor (CTS) is reporting abnormally low readings. CTS is used to control fuel mixture, timing, idle speed, TCC and EGR operation, among others. The thermistor used has a high resistance when cold, lowering as the coolant warms. This error then, indicates a very high resistance in the CTS circuit.
CODE 33
Trouble Code 33 indicates that the Mass Air Flow (MAF) sensor is reporting more air is entering the engine than makes sense based on RPM and TPS. The MAF sensor produces a frequency output; around 30 Hz at idle to 150 Hz under acceleration. The frequency varies proportionally to airflow. The ECM monitors the frequency and thus determines airflow into the engine. Typical idle MAF is 5 to 7 grams per second.
Anonymous
  • Posted on May 21, 2011
SOURCE: How do I actually get to the circuit board on dishwasher
Hi All,
Great web-sitevery useful. To add, my SB907 has same problem - not heating. Found no open/short circuit in heater - found this forum - followed through with removal of circuit board and ... BINGO ! Dirty big black burn mark under relay ! Am now wondering if I can "just replace relay"... any thoughts? Thanks Rick
Samsung dishwasher dw80h9930us diagnostic mode e3
Hey Randy, thank you for the query. According to my research the E3 error code means that your dishwasher is unable to fill with water. To fix this problem, turn the water supply off and unplug your dishwasher from the power socket. You can then remove the water hose and check the water inlet valve to ensure it's working correctly.
2answers
How do I start my Samsung dw80m955oug dishwasher?
Shut door, select cycle and options, press start.
1helpful
LG Dishwasher LDS5811ST does not drain last rinse out. LE code displayed. Did the shutoff of power. Most say PCB assembly, some asy control board - ?
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
LE CODE ON LG DISHWASHER
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective.
I am getting error code 3. Is there some solution that we can fix this ourselves or do we have to call a service repair guy in? Please advise and thanks.
Hello nlua0130 - Typically error code 03 indicates that the dishwasher has detected a sensor failure between the wash motor or wash motor hall. For this particular issue, contact a professional to move forward accurately. A certified technician will need to check the wiring between motor and main control board. Depending on the diagnostic either part will need replacing.
2answers
Samsung Dishwasher (DMR57LFS): Error code oE. Fills...fills some more...then drains.
Samsung Dishwasher 0E Error - We had other appliances on that circuit. We believe when those appliances were turned on it created an undervoltage condition in the dishwasher, causing another sensor to send the high level error code 0E. We believe this is the problem because it only started after we added the new hot water dispenser on the same circuit. The problem went away when we leave it off for the whole dishwasher cycle. I'm guessing it could also be caused by brown-outs and other large electrical loads cycling in the same household. That's the theory anyway. The folks who sold us the dishwasher suggested turning off the breaker, to reset the computer. Good idea, but not for our particular case.
1helpful
GE Dishwasher GSD700 not cycling
buy new dishwasher, if you spend the money on the motor plus your labour yo will still have an old one at that and next time something else will go wrong , like the solenoid or timer or circuit board or the impeller seals, etc. Vitally
2answers
I managed to locate the vanes and fixed the problem. Thnx for the help on this Board.
Top Samsung Dishwashers Experts
vince
Daniel Blask
Daniel Blask
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
