SOURCE: my problem is i want a digital camera has 10 to 15
I HAVE A SONY CYBERSHOT 5 MEG PIX WITH A CARL ZEISS LENS AND I LOVE IT IT OUT PERFORMS THE 8 MEG CYBER SHOTS
SOURCE: I need help fixing my camera
Next stem is to check a SMT fuse on dc/dc board.
You'll have to disassemble it.
SOURCE: Kodak m1063 do I need a camera dock to download pictures ?
Try a smaller memory card. I had an 8 gig card in the camera and the pc would not recognize it. I switched to a 1 gig and it found it right away. The problem is in the pc not the camera.
SOURCE: My Kodak EASYSHARE M1063 camera won't turn on
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
