How much is the camerea worth? how do i check the shutter count?
SOURCE: sound solution plz
goto control panel switch to classic view , double click add remove programs , then when the list comes up look for service pack2 and remove , then restart computer
SOURCE: I need drivers for laptop sps 1210
all Drivers for your computer can be found here
u most look what u already got what not
If it helped rate fixya
SOURCE: I have a Lumix DMC-FS3 camera and if I don't put a
First of all, forget about using the built-in memory...it's very small. Does your camera work properly when a memory card is inserted? You could also go into the setup menu to "reset". That would set your camera back to factory defaults.
Testimonial: "Thank you for quick reliable service!"
SOURCE: Panasonic Lumix DMC-FS5 cant upload photos!!
Did your friend use the "safely remove hardware" function when removing your card from her computer? That could corrupt your card if she didn't. Try this...take your card to a store like Walmart that has a Kodak picture kiosk. They can usually read everything on a card. There, you can print the pics or even make a cd of them. Afterwards, format your card in your camera.
SOURCE: important photos are stuck in the internal memory of my camera.
Select the Display mode with the top dial. Press the Set button to bring up the menus. Press the Rev key to scroll down through the menus. On the second page of menus, select the Copy menu. Then press the Lightning Bolt key to scroll right. Select the top of the 2 menu items. This will copy the internal pics to the memory card, assuming you have a memory card inserted.
