Instead, the following messages appear: "Jitterbug home screen is not responding" and "Would you like to close it?" (... with these options: "Wait" or "OK", neither of which correct the problem. Powering off the phone completely and restarting it has no effect, other than to display the above messages again -- to no avail. Please advise.
Try the options suggested here:
http://hardmasterreset.com/hard-reset-greatcall-jitterbug-smart/
SOURCE: Model No'DMR-ES15 - U61problem
I get this message occasionally on my Panasonic DMR-ES15. It's actually a really simple fix. It occurs when there is a corruption in the disc which causes the recording mechanism to malfunction. There is a separate error message for this, however it is usually not detected until it's too late. When the recorder asks you to carry out the recovery process, do it. When the disc ejects, make sure you take the disc out that was in there when it occured and throw it away...it will keep happening because the disc is permanently corrupted. However, do not close the tray without a disc or the self-check will fail. Instead pop in a disc of the same format that the error occured in (if it was DVD+RW then put in a DVD+RW). It resolves the problem every time on the first try. (It only happened two times in a year and a half for me). As the manual says the unit is "NOT BROKEN".
SOURCE: HP Pavilion dv7-1240us does not restart
Press and hold the power key. It should shut down (or just pull the power).
Restart the PC and do not press the escape key
SOURCE: My G1 screen stopped working so I got locked out
Turned my g1 telephone off and went to put it on again the android loads then the screen goes blank.
SOURCE: Mystery message "wait" appears above "following
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a compressor issue rather than thermostat? Thanks
