How to clear call for p/m fuser web on a panasonic dp8035
not a great idea seeing that the fuser web is needed to clean the hot-roller, so i would suggest to have an authorised dealer replace the web. if however the web has been replaced , and you just need to clear the counter, this is what to do:
get into service mode by pressing and holding the "function", "original size" and "3" buttons in rapid succession. sometime a bit tricky.you should see F1 self test on the screen.if not, press the yellow all clear and try again.
once in this is what the manual has to say:
"Call for P/M Fuser Web" (Default: 240K)
1. Perform the P/M (Preventive Maintenance). Refer to Section 3.3 and 3.4.
2. Press the "Function", "Original Size (Ledger/A3)", and "3" keys simultaneously to enter the Service
Mode.
3. Enter the password, and select "OK" button (default password is 00000000).
4. Enter the Copy Service Mode F5-73 (Fuser web) PM cycle and change to the desired value.
5. Press "Function" and "C (CLEAR)" keys simultaneously to exit the Service Mode.
hope that helps>
mario
