Refrigerators Logo
M
Mary Lee neel Posted on Apr 21, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After moving a kitchen aid refrigerator on its side, how long after before plugging it in?
Gil Shultz
Level 3:
  • Refrigerators Master 3,464 Answers
  • Posted on Apr 22, 2018
Gil Shultz
Level 3:
Answers
3464
Questions
Helped
731668
Points
11104
When you get up in the AM if it is upright before you go to bed. The longer the better, that gives the oil to drain back to the compressor.
5 Related Answers
Anonymous
  • 35 Answers
  • Posted on Apr 13, 2008
SOURCE: How to reset fridge light - Kitchenaid side by side
this may or may not help. Most SMART devices forget their SMART functions when your unplug them and wait a few seconds then plug them back in this should reset it!!
Anonymous
  • Posted on May 26, 2008
SOURCE: Refrigerator stopped cooling
I have the same problem on my GE model :
GTS18FBMERWW
It is a 18 cu ft, top freezer model.
If you get an idea please let me know.
TK
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Mar 19, 2009
SOURCE: Kitchen Aid Refer: KSSC42FMS01: The freezer, doesn't go below 32
How long have you had this refrigerator and is this the first time this has happened? Your refrigerator has a control board and I believe the board is causing the refrigerator not to defrost every 8 hours. Let me know these questions and I will help you resolve this. Thanks, Sea Breeze
Anonymous
  • 700 Answers
  • Posted on Mar 26, 2009
SOURCE: Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
mgprice
Mike Price
  • 744 Answers
  • Posted on Jul 11, 2009
SOURCE: Problem with Kitchen Aid side by Side
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
My kitchen aid refrigerator won't stop buzzing
If everything is cooling right, take the front grille off at the bottom of the fridge and move the plastic drip tray. It might be touching the motor or pipe, causing the noise.
How to move kitchen aid side by side refrigerator
usually has wheels and ifu push down on the front they should come out, or try lifting up and they come out then u can roll it
Kitchenaid superba ksrg25fkwh01 wire harness
Called Kitchen aid and protested, frig was 4 years old at the time. door was almost $1200 to replace. Kitchen aid paid for new door and installation
Problem with water and ice
My kitchen aid superba sie by side stopped making ice. I've changed the water filter and did the trouble shooting options in the book. Everything else is fine. Can you give me any suggestions
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Kitchen aid refigerator: door won't seal then lost power.
The GFI had becme stuck - yes we had plugged the fridge into the GFI which is apparently a bad thing to do. Replaced the GFI (and moved in away from the fridge) and all is well.
5helpful
Compressor runs continuously, and center bar (heat dissipator) is extremely hot to touch.
Molly, The hot bar is a normal part of the sealed system (compressor) operation. The relay they told you about is on the back of the compressor and I would not recommend you changing that. The refrigerator is a balanced system, the freezer air removes the heat from the refrigerator side. If the compressor runs all the time, look for food close to the edge and not letting the doors close completely. Move items back. Don't over pack the freezer, the air must circulate. The refrigerator of today runs longer and uses less power that the old refrigerator. If you are still having issues with this model call a authorized Kitchen repair person in you area and ask how much they charge to come to your house and give an estimate.
7helpful
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Agitator will not work
kitchen aid is hte same as the whirlpool so if you have directions for that one it will work on your current one,, part number 80040
Kitchen Aid Fridge
how long does it take for fridge to cool if its not been used in months?
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
