SOURCE: TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
SOURCE: Need menu control
On some tv's holding down one or two of the buttons on the front of the tv for a few seconds will bring up the menu. If it comes up you can probably navigate in the menu with the buttons on the front of the tv.
SOURCE: Sylvania TV stuck in Game mode remote no longer works
just go to channel setup and add/delete channel, it should exit the game mode. then do nothing unti the add/delete option exits the bottom of the screen.
SOURCE: Sylvania SST4272
I had the same problem with a Sylvania SRT2227S. I kept trying to fix it using the remote but after reading your posting I pressed the Volume (down) button, which cycled through the same menus you mentioned. Then I pressed the Power button on the TV and that fixed it.
The problem started for me when pressed PIP, CC, and Guide buttons on a Philips universal remote control. My TV does not support these functions and it seems to put it in this "service mode". Now I can fix it by pressing Volume (down) or Menu then the Power button on the TV (do not use the remote as it is useless when the TV is in this mode). I hope this works for you too.
Turn it on while holding the menu button on the side at the same time and hold it
