SOURCE: hobart dishwasher lx 30 h
Did the clean light indicator blinking over n over? check the element wire harness connector. If disconnected fix it and run your dishwasher again.
Also you may check the continuity of your heating element.
SOURCE: rinse not hot enough
145 degree is just your hot water temp and that your dishwasher hot water booster is not working assuming that this machine has worked in the past to produce final rinse water above 180 degrees. Remove the bottom panel and to the right you will see the booster tank, look for a nickel size component with a small red button on it. Try pushing on it to reset it. If that does not work, check for voltage at your heating element on your booster tank. (the thicker wires) If voltage is present then your heating elements need replacing.
SOURCE: what is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
SOURCE: is it possible to extend the rinse cycle on a
no the rinse time is non-adjustable it is built into the main control board
