SOURCE: how to set the time on a tag heuer
Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
Don't forget to rate, please.
SOURCE: Tag Heuer Aquaracer calendar problems
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
SOURCE: I can't seem to set the time on my used tag heuer watch
anticlockwise.
PS
anyway.
SOURCE: My TAG Aquaracer bezel moves counterclockwise
Yes, there are solution for that, but you will not be able to solve it yourself as the new part is needed.
That new part is called BEZEL SPRING and it is fitted underneath the bezel.
Bezel spring has special hooks pressed into it and allows to turn the bezel one way only (anticlockwise), at the same time stopping the bezel to turn clockwise.
Another cause can be that the dirt and grime are collected between the bezel and the watch case (this is where the bezel spring is located) and is stopping functionality of the bezel spring by leting the bezel slide over the hooks. This can be fixed by cleaning the watch case in ultrasonic cleaner.
Anyway- if the bezel is rotating on its own, I suggest that the bezel spring is broke and you will need to replace it.
Do not forget to rate, please.
SOURCE: My tag heuer aquaracer has a problem: the second
Your TAG is fitted with EOL (end of life) feature. This is the cause of
that 4-5 seconds interval movement of seconds hand and thus indicating
the time for battery replacement. The timekeeping is not affected by
this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
