SOURCE: MY LG WASHING MACHINE SCREEN KEEPS ON SAYING OE
It is a long drain error and appears when the washer is not fully drained after 10
minutes of draining. It can be due to a clogged or kinked drain hose, clogged pump filter, or the pump is not working properly.
LG Front Load Washers Drain Problem Troubleshooting and Repair Guide
Please let me know if you need further assistance regarding this problem.
SOURCE: E2 error comes up on
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
SOURCE: PYE Washing Machine AWM800 won't
Hello
This is a drain pump error code.The pump is either jammed or clogged.It will need to be removed and cleaned out.
SOURCE: Haier HWM5TL E2
You replaced the lid. Did you transfer any possible latch devices from the old to the new lid. Some lids have a magnet that has to be transfered. That magnet activates the switch. Some lids have a plunger or arrow shaped device that needs transfered that goes into a hole to activate the lid switch. Hope you still have the old lid to look at.
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed
when either the motor is not working or the control board thinks that the motor
is locked up. A Hall Effect sensor is used in these washers which monitors the
speed and direction of the motor and then forwards this information to the
control board. Hope you understand by now that this LE error is displayed when there
is an issue with the motor or when the Hall Effect sensor sends wrong signal to
the control. Conclusion is you'll have to check both motor and hall sensor and
replace the part# that is bad, usually I have seen the sensor going bad. Please
get back to me if you have any other questions.
Kevin
