Yellow light blinking. Cannot print. Can You recommend a Fix?
If your access point does not support WPS, we have provided alternative instructions for connecting your PIXMA printer, so please choose the' Standard Connection Method' below.
WPS Connection Method for Canon mg3500 Setup
Before we start, some conditions must be met to use the WPS push button method: a physical WPS push button must be available to the access point.
Please search for information with the user manual for your device.
If there is no WPS push button accessible, kindly use the Standard Connection Method directions.
The WPA (Wi-Fi Protected Access) or WPA2 safety protocol must be used by your network. This protocol is used by most access points enabled by WPS.
Step 1: Check to turn on the printer.
Press and hold the[ Wi-Fi] button at the top of the printer until the alarm lamp once flashes.
Step 2: Make sure you start flashing red next to this button and then go to your access point and click the[ WPS] button within 2 minutes.
Please refer to its user guide for information on beginning WPS on your access point.
Canon mg3500 setup
The (blue) printer Wi-Fi lamp will continue to flash while looking, and when connecting to the access point the energy and Wi-Fi lamp will flash.
The power and Wi-Fi lamp will stop flashing and stay lit when the printer has successfully connected to your wireless network.
Hi, you need to count the blinks to know what error is.
SOURCE: Canon pixma IP 1500
Seat the print head
Below is the procedure for seating the print head and ink tanks:
Ink tanks installed correctly
Ink tanks installed incorrectly
Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
SOURCE: how to fix my canon pixma ip1000 printer will not print black ink
replace the printer head....
SOURCE: Canon S630 Printer. Yellow light blinks 7 times, green once.
7 Blinks says that your printhead has gone out. Just needs a new printhead, QY6-0034-000. around $40.00
SOURCE: Print head problems 7 yellow lights 1 green light, how do I fix
That's not a printhead problem, it's saying that the waste ink absorber is full. You need to have them replaced at a shop where they can also reset the waste ink counter.
