SOURCE: faded spot on one side?
clean toner drum and if problem not solve so clean also fuser and scanner assy.
SOURCE: Samsung color fading-light on lft side to dark on rt side
i want to download the driver softwere of samsung clp-300 series vista ultimate supported
SOURCE: HP Color Laserjet 2600n. Magenta color
This has become a common issue on these machines - due to design two laser-to-drum mirrors in the laser/scanner assembly face upwards. Because the unit is not sealed, the upward facing mirrors are a nice place for toner dust to settle.
The repair is rather easy for a trained professional - in theory anyone with the right set of instructions could perform the procedure, but I'd highly recommend a novice not try.
Instead call a trusted computer repair shop and explain the situation and that you need to have the mirrors in your laser/scanner assembly cleaned to resolve issues with faded color output. A reputable service agency with experience in HP printer repair should have no problem doing this procedure in less than an hour – so they shouldn’t charge you for more than an hour or two of bench labor. If the repair facility you contact doesn’t understand your request or tries to blame your toner cartridge; hang up and call another company.
