SOURCE: Magic Chef Oven lights and shuts off
This could be caused by a lack of air within the oven cavity, once the air is used up the flame will go out, it will then work again once it is relite, but will probably do the same again, this could be dangerous and requires on site proffesional attention. Regards Engineer
SOURCE: Re:Whirlpool SF310PKE gas range
When the oven safety valve refuses to open and let gas through, it's almost always because not enough current is flowing through the ignitor. Often an aging ignitor will appear to be glowing pretty brightly but still won't draw enough current to make the valve open. The first thing to try replacing is the ignitor.
You describe your ignitor as "red and glowing" but oven ignitors normally get a lot brighter than "red" -- well into what I'd call yellow.
SOURCE: Whirlpool 465 oven temp
Go to Calibration mode and adjust the temperature up by 10, 20 or 30 degree. This is in each manual.
SOURCE: GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
