Question about Frigidaire Ovens
Frigidaire double wall oven timer volume too low to hear. How can we make it louder
6ya staff
SOURCE:
Anonymous
SOURCE: panel light is out
There is a capacitor on the clock board labelled C3. It will probably have brown burns on it or "syrup" leaking around the base. You can buy a box of 10 of these for 75 cents at Radio Shack (make sure you match the label on the old capacitor, I think it's 58mf and 35V but I could be wrong) and a pencil soldering iron for $10. It's held on with 2 little wires. Before taking it off note capacitor orientation (where the blue +++ stripe is), the replacement has to go on the same way. Common problem and easy fix.
Posted on Jun 21, 2008
apart4u
apart4u
  • 213 Answers
SOURCE: timer alarm volume is down
iam sorry to tel you there is no way of turning it up you would have to get a new timer
Paul http://www.apart4u.co.uk
Posted on Mar 04, 2010
siscor
SOURCE: volume control candy oven timer
Switch off the oven, leave for 5 seconds and switch it back on.
Candy Customer Services asked for over £100 to have an engineer sent to my house, which I refuse as I thought the oiven was good.
I had to switch off all the electricity in the kitchen but after this 'reset' the oven turned to the normal 'high' volume.
Posted on Aug 03, 2010
bbt1968
SOURCE: I have a Frigidaire Custom Imperial double oven
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Posted on Dec 11, 2010
machinetech7
Jason Kennidy
  • 1344 Answers
SOURCE: how do you remove the door from a frigidaire gallery series double wall oven(self cleaning)?
Open the door and look at the hinges the connect the oven door to the oven body, on each side you will notice a piece that can be moved back and forth without moving the door, roll each side toward the oven body this should be the locked position, now try to close the door and you will notice the hinges lift up. At this time you need to pull up and push forward on the door and both hinges will come out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Apr 25, 2012
Frigidaire double wall oven clean between the glass
Remove door off the hinges. Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Apr 09, 2014 | Frigidaire 27 in. Electric Gallery Pro...
I need a controls manual for a frigidaire LEEB30T9FEA. I have the Owners Manual and the Installation Guide but neither has how to use the controls of the oven.
Hello - I understand you are seeking a control manual for a Frigidaire Double Electric Wall Oven LEEB30T9FEA. You can download the manual to your unit here under the Timer Guide. I hope you find all the information that you need.
Mar 09, 2013 | Frigidaire 27 in. Electric Double...
INSTRUCTION MANUAL FOR LEEB30T9FEA
Hello Brent Delong - I understand you are seeking a control manual for a Frigidaire Double Electric Wall Oven LEEB30T9FEA. You can download the manual to your unit here under the Timer Guide. I hope you find all the information that you need.
Mar 08, 2013 | Frigidaire 27 in. Electric Double...
Timer volume too low
some units can be adjusted for louder tone volumes,depending on your model you can check the user manual supplied with the oven to find out if volume increase is possible or go to maytags web site and you can download a user manual or ask them online if its also possible to do this with your model
Nov 29, 2012 | Maytag Ovens
I have a Hotpoint Double oven DQ471/2. The timer bleep is so quiet I cannot hear it and my partner who has a hearing difficulty finds it impossible. Our old New World oven had a bleep which was...
unfortunately there is no way of increasing volume of the bleep. its basically a simple beeper on the timer with no way of adjusting.
sorry cant be of much more help but what i will say is you should contact hotpoint about this problem as obviously is a design flaw.
Mar 18, 2011 | Hotpoint Ovens
Volume on timer really quiet hotpoint forno
Pressing the "-" button on the control panel will cycle through the 3 or 4 available beep tones / volumes. No need to press any other buttons during or before this process.
Shame Hotpoint didn't see fit to put this in the manual. We dicovered it by mistake!
Jul 29, 2009 | Hotpoint UY46 Style Line Stainless Steel...
I have a Frigidaire Custom Imperial double oven which still works gret after all these years. But, the clock just died which means the timer doesn't work or the clock to turn the oven on using the timer. I...
Mar 24, 2009 | Ovens
I started my oven on ''clean'' -- how long should this take?
Whithout knowing the model number in general it takes several hours for the cleaning cycle. My oven takes approx. 4 hours to complete a good cleaning. On my own oven, you can set the timer for as long as you want. Do you have an owners manual? If not, you can find one here...........
http://www.frigidaire.com/support/manuals.asp
Mar 20, 2009 | Frigidaire 30 in. Electric Gallery Series...
How to calibrate double wall frigidaire ovens. temperatures are not true to digital control.
plaese post model number to assist you further. directions for calibration should be in user manual..
Feb 21, 2009 | Frigidaire 27 in. Electric Double...
Ovens Logo
285 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
