SOURCE: Toshiba 23HLV87 - has built in DVD player
my dvd is saying no disc in the player i have a 23hlv87
SOURCE: HDTV Turner
If your set has HD on it means set is HD Ready and you do not need Converter Box even if your only signal is coming from an antenna. Either a TV has HD or it Does not! And NO you cannot buy Parts to make your set HD.
SOURCE: about Sylvania TV
Hi malumbender,
Your tv dosn't have a digital tuner, in order to recieve OTA (over the air) digital signals you will need a Digital Converter Box.
Here is a link to a government website for coupons for the box.
The coupons are for $40 off the purchase price of the box.
There is a waiting list but they will come available as other coupons expire.
https://www.dtv2009.gov/
here is another site for antenna and channel line up.
http://www.antennaweb.org/aw/welcome.aspx
I hope this helps and please rate this solution, please keep in mind that a "Thanks For Trying" rating is negative.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: digital built in turner
You'll need a better antenna. All the TV can do is show you the signal strength at the antenna input. If it's too low, only changing the antenna can help. This could mean simply adjusting the antenna position. You might need to replace the antenna with something larger or with a built-in amplifier. In severe cases, you might need to install an outdoor antenna to get a useable signal. With digital broadcasting it's all-or-nothing. A weak signal will either go undetected by the tuner or cause a blocky freezing (pixellated) display.
SOURCE: Does this model have a built-in QAM tuner?
Yes it does.
