Heating & Cooling Logo
d
daryl whaley Posted on Apr 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
'on how to light piolet on 18000 btu big buddy heater
Can k light piolet with lither but no with unite
Roger S
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 72 Answers
  • Posted on Apr 14, 2018
Roger S
Expert
Level 2:
New Friend:
Greenhorn:
Answers
72
Questions
0
Helped
10326
Points
138
You should be able to light a pilot with a lighter or match if the built-in igniter won't do it.
Make sure you set the ON/PILOT/OFF button to the PILOT setting, push in on the button while lighting the pilot light (flame), and keep holding the button down for about 20-30 seconds. Then the pilot flame should stay lit.
5 Related Answers
Bill Long
  • 606 Answers
  • Posted on Jul 12, 2009
SOURCE: Just put in a new ac unit and replaced a old one.
The 18,000 btu A/C is 230 volts, are you sure the 12,000 btu unit is 230 volts most are 120 volts.
Usually 12,000 btu is the biggest 120 volt A/C you can buy.
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Nov 12, 2009
SOURCE: The heater piolet light goes out when you move to use the heater
There is a thermo coupler that shuts the gass off if it is ba. It is locacted just in front of the pilot flame It has to sense the pilot to let the gss through. It is an easy fix and inexpensive.
Anonymous
  • 115 Answers
  • Posted on Dec 13, 2009
SOURCE: my big buddy heater has sat all year and now it
you may have cobwebs in the gas orifices. shut off gas and power then poke each hole out with a wire turn on gas and power and try again
Frank Bryant Wetzel
  • 456 Answers
  • Posted on Jan 12, 2010
SOURCE: do i use 10-3 withground?
A normal 2phase 220 or 240 V unit usually requires
2 wires and a ground. If you know what a contactor
is you will notice that only two line voltage wires can
be inserted into it and the ground wire to the equipment ground.
If you have a 3phase unit you would need 3 wires and a ground. Usually on the back cover of the unit it will
show the wiring diagram
roniecon
Ronny Bennett Sr.
  • 6988 Answers
  • Posted on Jul 05, 2010
SOURCE: AC unit LWHD 1800R won't turn on & test/reset does not respond.
Reverse the wires in the receptacle ,not the ground,this is most likely the problem the way the circuit is set up in the ac unit.Let me know if this helps.
Cannot get it too light
PDF]operating instructions and owner's manual - Rural King
www.ruralking.com/.../MH9BX_Portable_Propane_Heater_Manual.pdf
light, adjust or operate the heater. PORTABLE PROPANE HEATER FOR RECREATIONAL AND COMMERCIAL USE. MH9BX. Model #. 02/09 32030. MR.HEATER, INC., 4560 W. 160TH ST., ... Get fresh air at once! Have heater serviced. speciFicatiOns. MODEL NO. .... Some people cannot smell well. .... Buddy series hose.
Mr. Heater Portable Buddy Propane Heater - Bass Pro Shops
www.basspro.com/...Heater-Portable-Buddy-Propane-Hea...
Bass Pro Shops
1helpful
My little buddy heater wont stay lit
If there is a draft it will blow out, if you run into it there is a safety shut off. If neither of those are the problem then I would check your regulator.
I am looking for0.8 tons a c of price 10000
This is a fix it site. check your local kijiji or craigslist.
How to relight piolet
The H Series electronic ignition does not have a pilot light. It has an electronic ignition that, if all conditions are met, will start the heating process
Iced over. compressor runs super cold. no control on temperature.
It's requires clean up , it's all covered with dust and that caused it to freezes and iced. It will consume more electricity when gets iced.
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
1helpful
Piolet stays on,. burners do not go on heater will not start
could be many things ,start with pressure switch,check for continuity with multi-meter.if press switch isnt sensing water flow, your unit will not call for heat.let me know
1helpful
Lighting the pool heater
You will need to buy a new thermo couple 8.00 part from ace it is the little copper line close to piolet flame,it sences the piolet and allows the gas to open and feed,it is wore out,burned out,replace.
Top Heating & Cooling Experts
Paul Carew
john h
