When I idle it down I have to do it very slow to keep it from back firing and as I engage it in gear it pulls down I have to stop let it idle back up and go and stop and go its just a few seconds to idle back up each time.
SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
SOURCE: Kohler command 20 Hp. engine on walker mower
you can lub it up with some 3m oil if that dont fix it than it may need a new one
SOURCE: Kohler Command V twin 20.5
I think that there is still a piece of trash in the idle circuit. Did you remove the adjusting screw when you cleaned it?
SOURCE: I have a 20 hp. Kohler command the engine idle goes up and down when the pto is turned off.
clean the carb
