Wharfedale LCD37F1080P TV getting a Blue Power on & off light.
My TV was working fine before I went out, when I went out I turned the TV off by Remote as normal but on coming back in I plugged an XB1 power lead into another socket but when I went to turn the TV on I noticed it was flashing on and off with no sound or Picture, I don't have the Cash to but another TV either and need it for my Xbox 1 is there a simple fix that I'm able to fix this issue please, thank you.
Press and hold down MAGIC until the red light blinks twice. (The red light will blink once and then twice.)
Enter your (four-digit device code) using the number keys. The red light will blink twice.
Now, aim the ONE FOR ALL at your device and press POWER. If your device switches off, the ONE FOR ALL is ready to operate your device.
Turn your device back on and try all the remote's functions to ensure they are working properly. If the functions do not work properly, repeat steps 1-5 using another code listed under your brand.
If your device does not respond, follow steps 1 to 5 with each code listed for your brand.
Wharfedale LCD3210HDAF this tv was working fine the night before ..
when i turned it on in the morning the screen came on then instantly
went blank .. although the sound is fine i am unable to get any on
screen including menu an volume information and of course can any one help ??
Try putting the cables back where they were. After that re-route them again but this time use the manuel.
If that doesn't work, consult the TV's manuel.
Change you screen resolution to lower resolutions, like 640x480, connect it. if you get video, move your resolution up and test which ones work for you TV. Try to stay under 1920×1080.
hi here is what you do go into menu go to feature thento ext 2 out then press right blue button on remoteand find the ext you need make sure your tv volume is turned down make sure your surround sound is on and turned up wait and you will here your sound when you have the right ext i have hdmi lead in ext 5 so it ext 5 that will show in the feature menu i hope you find your problem solved allan
