F494 is an ecu problem https://www.justanswer.com/heavy-equipment/1kuex-jd310-no-yr-s-shows-service-engine-soon.html John Deere 310G ECU Codes usually its a connection /broken shorted wire to ecu John Deere Fault Codes also notify a john deere dealer service about code for your unit they may have a fix or may need to flash ecm
SOURCE: Missing manual and all paper work for John Deere Ertl #37565
i have no manuel for the 850j remote control dozer from john deere
need to know where the charger plugs into the machine
SOURCE: hydraulic reverser problem with John Deere 1010
ineed to find a hydraulic reverser for a 300D john deere backhoe
SOURCE: How do I change the track tension seal in a John Deere Dozer 450 series?
You may have this
posted in the wrong product category. Please select another category
appropriate to the problem and re-post the problem so the correct
expert will see and respond to the question..
This is for
car and truck problems.
