SOURCE: Whirlpool DWH B10 - under IKEA
Hello Shazzastu,
I think there is on manual online for the product you need,
However i advise you to click Here and contact Ikea to install your dishwasher
Good luck,
Dahaka
SOURCE: is this hot or cold feed
This dishwasher should be connected to the hot water line under the sink. If it is connected to the cold line, you will have very poor cleaning. The hot water should be 120 degrees (F) minimum and less than 140 degrees.
SOURCE: Whirlpool / IKEA Dishawasher DWH B10 - castor wheel
make sure there aren't any screws through tabs at the top front of the washer that fastened it to the counter top.
SOURCE: NO WATER IS PUMPED UP INTO THE MACHINE
Check the fill switch on the inside of the dishwasher. It should be located on left front bottom of inside. This gets stuck alot.
SOURCE: whirlpool dwf b10 manual
Try this site
http://www.whirlpool.co.uk/support_instructions-for-use_instructions-for-use.content.html
then enter in DWH B10 and you should be able to download a PDF manual
