I need to repair / replace the inner microwave control board and / or the control panel button control
SOURCE: damaged inner seal tape on whirlpool microwave door window
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I
made) that demonstrates how it's done.
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: Control Panel of Maytag Microwave CMV 1000B doesn't work
You have a failed
membrane keypad.
If you (or someone you
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very
helpful
when troubleshooting & testing.
If you would like to
have us do this repair for you, we do that for $39.95 plus part costs.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your
model number) for more information & help.
We're
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: Owners manual for Kenmore Elite Microwave Model 66462
A full
Sears/Kenmore model number has 3 digits, a dot, then 8 more digits,
such as ###.########
You can just enter your full
model number at the Sears
parts site.
On the resulting page, look to the right for the blue "View manuals"
button. Click there.
That Sears-related site has many free manuals. While the manuals they
list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions
inside.
If yours is not listed there for free, you would have to order it
through the Sears
parts site.
We're
thoughtful rating of our answer.
SOURCE: Broken door latch on Model 63679 Kenmore Elite Microwave.
You have to separate the door panels (as shown in the attached photo)
You can find helpful exploded views by entering your full Kenmore model number at the Sears
parts site.
A full Sears/Kenmore
model number has 3 digits, a dot, then 8 more digits, such as
Please be aware that you may have a broken spring mounting tab on the inner door panel.
In such cases, the best way to fix that is to drill a hole in the remaining material, insert the spring, then add a dab of epoxy where they spring attaches to the panel.
We're
SOURCE: I need to replace the
1. Unplug the microwave
or turn off its breaker.
2. Open the door, then
detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without
disconnecting the wires.
If you have any trouble getting the grille off once the
screws are
removed, slide the hood vent grille to the left about 1/4", then then
pull it forward.
On some models there are L-shaped clips that fit
into a slot to hold bottom of the vent.
exploded view diagrams and order parts by entering your full model
number here.
They're our favorite supplier.
We're
