Refrigerators Logo
j
jerry Posted on Apr 10, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an LG Refrigerator, number LRBC20512WW. I need to know how to remove the freezer door rack
geob91
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 128 Answers
  • Posted on Apr 10, 2018
geob91
Expert
Level 2:
Passionate:
Answers
128
Questions
0
Helped
83389
Points
414
From the drawing it looks to just lift off. If anything spilled on it then it might be stuck in place but I do not see any clips holding it in
I have an LG Refrigerator, number LRBC20512WW. I n - 50031649-00004-3dvc3rq02kdqjihqd3tusqf5-3-0.png
5 Related Answers
Anonymous
  • 63 Answers
  • Posted on May 30, 2009
SOURCE: is there a kenmore refrigerator recall?
The 800 number is available at:
www.techimo.com/forum/imo-community/145834-lg-electronics-sears-roebuck-recall-refrigerators.html
littlepear
Littlepear
  • 7 Answers
  • Posted on Jul 06, 2009
SOURCE: Broken Optibin door on LG refrigerator
I got a new bin from repairclinic.com, but the little nubs that hold the bin onto the door (in the thin plastic lining of the door itself) are snapping off. Sigh.
Anonymous
  • Posted on Apr 15, 2010
SOURCE: Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
LG help guy
  • 112 Answers
  • Posted on Jul 25, 2010
SOURCE: Freezer light no longer comes on.
The switch and or the led light assy has ice inside of it. This is a known issue with this LG unit.
Call LG and request them to fix this under a warrranty.
Good luck.
Anonymous
  • Posted on Aug 13, 2010
SOURCE: LG LFC23760ST Side by Side Bottom - Slow Blow or fast blow fuse?
slow
Er ff
You need to remove the freezer door and basket. then remove the rails on both sides. then there is a panel at the back of the freezer. Pull at the top part of the panel and it will come out.
1helpful
I have a LG model LFX25960ST refrigerator with an error code of FF. I know this means the freezer fan, but is that one of the fans located in the freezer? When looked up online, neither of those two fans...
yes, its located on the freezer; behind the rear wall. yours has 2 fans; one for the ice cube room (upper left corner) and the fridge/freezer motor (in middle) behind rear freezer wall. this is the motor you will need. the part number should be on it.
Freezer section 26 deg f. refrigerator section 58 deg f with both dials set on 3. refrigerator section not cold even if dial is set to 4 or 5
when you open the freezer door do you hear the fan blowing,also is there any like snow or frost on the freezer wall inside the freezer,touch it and make sure or was the door left open?is there frozen water droplets on the food packages and on the racks,let me know what you find and send the model number,open the fridge door and look on the left side wall near the ceiling
1helpful
Lrbc20512ww- icemaker is putting out ice and water,and freezes to 1 solid piece
ADJUST THE CUBE SIZE USING INSTRUCTIONS IN YOUROWNERS MANUAL. iF THIS DON'T WORK, REPLACE THE WATER VALVE.
1helpful
Door display shows eror code FF
This means your freezer fan is not working and you'll need to replace it. It's one or two small plastics fan that sits behind your freezer drawer. It's located behind one of the two wall panels behind your freezer drawer. They circulate the air flow throughout, one for your refridgerator and the other for freezer. I had to have both replaced and now my line holder in the bottom back right side of my refrigerator is leaking, so I had to shut off my water until we find the part number. Good Luck! I know I'll need it because my wife has all LG in the kitchen including a flat T.V and 2 microwaves.
William,
Is there a kenmore refrigerator recall?
2answers
The refrigerator section is not cooling
Don't know if you have had this fixed yet, however LG did have a frosting problem with some of their units. The fix was in the main board, programing change, get a new board and it should solve the problem. Another problem that may occur is a build up of ice that can block the fan. Cut off the excess insulation as in the picture and that will solve that problem as well.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
