Televison & Video Logo
S
Steve Mullaly Posted on Apr 10, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can anyone please tell me what the hidden service code is for a Sharp Aquos 3D Quattron (LC-60LE835U) is and how to access. TIA
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on Apr 10, 2018
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
782879
Points
6681
1 Related Answer
gopakumarg43
  • 76851 Answers
  • Posted on Mar 17, 2014
SOURCE: I forgot the parental control code Aquos Quattron TV Sharp LC-40LE835U, change the factory code, wanting to restore everything, ask me the code, and forget to the code. Note: use codes 0000,1234,3
Refer its user manual for more details. It will have the default reset code.
Sharp LC-46LE832U TV
Yes, it does exist!
Support Details LC-46LE832U - Sharp Electronics
www.sharpusa.com > Support
Home > Support > LC-46LE832U. LC-46LE832U AQUOS QUATTRON LED LCD TV ... Have a basic question about your Sharp product? Get started with the ...
LC-40LE832U ' LC-46LE832U ' LC-52LE832U ' LC ...
files.sharpusa.com > ForHome > LCDTVs > Manuals
PDF Consult the dealer or an experienced radio/TV technician for help. DECLARATION OF CONFORMITY: SHARP LIQUID CRYSTAL TELEVISION, MODEL LC- ...
AQUOS LC-46LE832U LED-LCD TV-LC46LE832U ' Eckley ...
www.eckleysappliance.com > Sharp-Electronics-LC46L...
On the LC-46LE832U, this technology is enhanced further with Quad Pixel Plus, which produces smoother lines by enabling the individual control of all 8-million ...
Sharp LC-46LE832U Manuals ' ManualsLib
www.manualslib.com > ... > Sharp Manuals > LCD TV
Sharp LC-46LE832U Pdf User Manuals. View online or download Sharp LC-46LE832U Operation Manual, Connection ... LIQUID CRYSTAL TELEVISION.
Trying to find out what's wrong with my TV. Sharp aquos quattron 3d LC-70LE757U No sound and picture is messed up.
Seems like main board fault. Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
White purple spots
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
1helpful
TV wont start up, blue power icon flashes 3 long and 1 short flash repeatedly
You need to reboot the tv. you've had a signal drop which locks up the tv. call sharp techicon1.png support and they will talk you through a reboot.
Vertical lines showing up after being on for awhile
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
