SOURCE: alpha numeric keypad of SGH-i750
go to inputs and choose T9 or click from where you get key board on the screen and choose T9
SOURCE: fault with alphabetical/numerical keypad
unplug and replug the keyboard
if that doesnot work replace the keyboard
SOURCE: I get a numeral 4 when i hit the "U" key
Kindly press fn+num at the same time and check if it will work...
SOURCE: Numerical keypad offset numlock on keyboard
Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders. Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values. hope this helps
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
