Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts./
SOURCE: HELP
will be a hardware error
will have to contact microsoft there is a temperory fix for this problem. what you need is two towels just normal bathroom towels take everything out of your xbox e.g
harddrive,controlers etc only things to leave in is the av cable and power supply as you wanna turn
on the xbox lie a towel flat on the ground and lie the xbox on its side ontop of the towel turn the
xbox on, you will see the error message and the red lights flash. wrap the towel around your xbox
covering the air vents and then the 2nd towel put over the top. leave it on in the towels for about
20 mins then after that take all the towels off turn off the console and leave to cool down for 15
mins. turn the xbox on and it should restart again fine but only lasts for a couple of days then you
have to do it again. wont fix it but will let u play while microsoft gets it.
hope this helps please rate me
regards Grant
SOURCE: timer light flashes tv won`t turn on. mitsubishi model #55859
You have a bad DM board - the capacitors are bad and need to be replaced. I was able to replace them myself. There are no replacement parts available and many repairmen will charge hundreds of dollars and there is no guarantee they will fix it.
SOURCE: Mitsubishi WD-82738 has no picture,
After rereading the symptoms you descibe what you describe might be a faulty colorwheel. When the set is first plug up there is a small mechanal motor that has to reach certain speed. if this does not reach that speed the set will not allow the lamp to fire. The whirring sound could be the colorwheel trying to spin up. these break all the time. (its a motor and anything that moves eventally will not.) it a fairly simple rep;air thatn most quilfied techs can repair. Such a repair generally should take more than a hour to do
SOURCE: I have a Mitsubishi tv model WD73 40 and the tv
Hello there,
This page refers
http://stereoandvideorepairco.com/Troubleshooting/MitsubishiShutdownTroubleshooting.html
See on this page for yourself
Code is 36 and definitely refers to a fan that has STOPPED
Have another close look, friend perhaps the fan sensor (if there is one) is dirty or moved ?
You can Bing or Yahoo the codes for correct error code response.
