These should work. How to Remove Nail Polish from Linoleum Vinyl Flooringeval ez write tag...
Try nail polish remover in very small bits and sop up the nail polish
find a section of the vinyl that is not noticeable and test if the nail polish affects the surface first
SOURCE: ps2 game scratches
the only thing you can do now is throw it a way as the nail varnish remover is all most pure acohol it as burnt in to the disk and there nothing in the world can remove it as it melted the plastic
SOURCE: How to remove ink from dryer
None of the chemicals you describe should be used. The heat or spark from the motor could cause a explosion.
Put some old laundry material in there and run it multiple loads with no heat it will eventually wear it off.
SOURCE: Dried fingernail polish inside of clothes dryer
Wipe it down with acetone and scrub with an scotch bright pad. the take some soap and water and scrub the drum down. dry it out with some towels and your back in buisness!! hope this helps PS don't forget to rank me if this answers your concern! thank you!!!
it's possible you got some inside your mac. When it heats up, can you smell the remover? It might be that it dried inside and is being reheated every time you use the mac.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
SOURCE: How do I remove super glue from my skin?
Acetone is often found in household nail polish remover, and a small amount on the end of a Q-tip applied directly to the glue should dissolve the bond without damaging the skin. How to Get Super Glue Off Your Skin
Do not use a cotton swab, as this can react very violently with cyanoacrylate
Do not do this on sensitive skin (e.g. lips, eyes, nose) or near an open wound
Other method if you dont have acetone with water & shave cream The Best Way To Get Super Glue Off Your Skin
Matte nail polishes do not shine like creme ones. They are very trendy these days although can be harder to apply to the nails as they don't glide when you paint them onto the nails.
