SOURCE: red is distorted on upper left corner only
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
SOURCE: DTV letters appear in upper left corner of screen
Consult operations manual to find definition. You might use remote to access menu, then press "display off".
SOURCE: Upper left hand corner of keyboard gets very hot
check if in that area any specific device is getting hot (battery, CD, )check connectors and remove any short circuit.
set BIOS to keep fan running when on power supply and always keep laptop on hard surface with free air circulation around.
Consider a ventilated support as you can buy on any shop for 20-50$.
If issue persists consider return for repair.
Pc shuts down for thermal protection.
SOURCE: TI 84 plus calculator, flashing dot in upper left hand corner
When you turn the calculator on, its screen is cleared, save for a small square on the top left corner. This is the cursor and it is blinking: The calculator is waiting for you to order it to perform some calculation.
Try this simple operation
[1] [+] [1] [ENTER]. The calculator will display the result one line down justified to the right.
Hope it helps.
SOURCE: Garmin gps keyboard -- left upper corner fails to
Sounds like you need to recalibrate the screen. This can be done by following the steps below:
To Calibrate the Touch Screen on a zūmo®:
1. Turn the unit Off and make sure it is not attached to any outside power source.
2. Power the unit On, continue to hold the Power button for 1 minute.
3. A screen will display that says, Press dot in the lower left corner.
4. Release the Power button and touch the sequence of dots until your unit says Calibration complete.
