A
Anonymous Posted on Apr 02, 2018
Can't find sharp Al 1217d driver on sharp website. Please where can i download it for windows xp
George Mclaughlin
Level 2:
Sergeant:
  • Sharp Expert 372 Answers
  • Posted on Apr 24, 2018
George Mclaughlin
Sharp Expert
Level 2:
Sergeant:
Answers
372
Questions
Helped
128237
Points
839
5 Related Answers
Anonymous
  • 2071 Answers
  • Posted on Jul 30, 2008
SOURCE: Driver for 5320
click below;
View Full Version : DRIVER NEEDED: Sharp Electronics Sharp AR-5320 (Windows XP Home)
Regards,
VOTIT
DON'T FORGET TO RATE
Anonymous
  • 10 Answers
  • Posted on Jan 17, 2009
SOURCE: Sharp Al-1216 Laser copier/scanner but doesn't work on my new Lap
www.sharp-usa.com
Anonymous
  • Posted on Feb 07, 2009
SOURCE: al 096 driver problem
I am having a sahara laptop model no. al 096 but I don't have driver for windows xp , please provide me xp driver of al 096 laptop of sahara
Anonymous
  • 1902 Answers
SOURCE: al096 sound driver for sahara nootpad
http://www.saharaglobal.com/support/list/step_1.jspc?lang=en&loc=INDIA
Now just look for your model number.
Anonymous
  • 63 Answers
  • Posted on Oct 15, 2009
SOURCE: drivers Sharp al 1642cs para vista 64bits
Ir a la ficha www.sharpusa.com de atención al cliente a continuación, descarga de productos. Categoría de producto elegir impresoras y multifuncionales. para el modelo seleccionado modelo no figuran a continuación, el tipo de modelo en AL1642CS. Para el tipo de descarga a continuación, elegir controlador presión de búsqueda en la parte inferior.
translated by goole
How to reset the alarm indicator drum cartridge replacement in my copier machine sharp AL-1217D and it is necessary to reset the machine if you install a new drum unit? please help.
to reset drum counter u have to go in simulation clear density clear density enter 24 press start button where u normaly press to make copy then enter 7 again press start button off your machine and back it on that,s it
I WANT SHARP 5316E SOFTWARE FOR WINDOWS XP
if i knew what device the software was i might be able to locate it for
these are only drivers
http://download.cnet.com/sharp-al-1645cs/3000-2116_4-80636.html
http://www.download.com/sharp-al-1551cs/3000-2116_4-70410.html?tag=api
these are at
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver
hope this helps you
HOW CAN I MAKE MY SHARP 1L 1661CS WORK WITH MY NEW DELL VOSTRO 430 WITH WINDOWS 7 PROFESSIONAL? THE COMPUTER TECH WHO SET UP THE NEW COMPUTER SAID THAT WINDOWS 7 DOESN'T SUPPORT THE SHARP, BUT OTHERS...
With Win7 Pro, you can download and install two programs from Microsoft. You need Virtual PC and XP mode. Download and install them in order from http://www.microsoft.com/windows/virtual-pc/download.aspx . You will have to assign an amount of memory to dedicate to the XP computer during the setup. Then open the program and install your laser printer to the new virtual XP computer on your Win7 machine as you normally would install the printer to XP. If you need the drivers, they are available here: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=Driver&category=HomeOfficePrintersFaxMachines&model=AL-1661CS& .
However, your files can't be shared directly. You will need to save them to external media (optical disc or flash drive) and then transfer them.
I hope this helps.
(I've got XP mode on one of two Win7 Pro computers in my facility)
Just need the driver for compatible with windows vista or windows 7
Hello. Go to the Sharp website and download the driver you need. Sharp.com/drivers
I need the scanner/copier part of the driver CD - Sharp AL-1655cs
I'm not sure where you downloaded the printer driver but the Sharp website has a download link to the printer and scanner driver according to their website.
http://www.sharpusa.com/products/TypeSoftware/0,1086,20,00.html
SEND ME SOFTWARE FOR SHARP PRINTER DIGITAL AL-1566 TO DOWNLOAD PLEASE
I assume you want the print driver - your request is not very specific.
go to this website to download http://www.sharpelectronics.info/Software.aspx
select your product and windows version.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
