I have a straight talk motorola phone, I want to switch to a Iphone 6s with verizon
There are different ways to transfer number from a Motorola phone to iPhone. Just follow the below steps to complete this task.
Move to iOS app can also be employed to transfer contacts from Motorola to iPhone free. It provides you much convenience when you plan to switch from Motorola to iPhone. Now let's begin to look at the following contents to know how to realize Motorola export contacts to iPhone effectively.
1. Download the Move to iOS app in the Google Play Store and then install it onto your Motorola and iPhone.
2. On your iPhone, swipe upwards to connect to Wi-Fi network. Then you need to launch Move to iOS app on your iPhone.
3. On your Motorola, run Move to iOS app and then connect to Wi-Fi network as well. After that, you need to check "Contacts" in the list and then the transfer process will begin. You should not switch to other apps or turn off the device until the process is over. When the transfer procedure is finished, your Motorola contacts will be available on your iPhone.
With Move to iOS app, you can realize Motorola transfer contacts to iPhone without any difficulty. However, among all transfer programs, iTransfer is the most professional one. If you want to know how to realize Motorola export contacts to iPhone with it, you can continue to read the third solution in this tutorial to assist you.
For more methods, check: How to Transfer Contacts from Motorola to iPhone
Contact your provider to port the number accross to new phone,you will need new phone details and imei number.
SOURCE: getting a pc suite for motorola v3c verizon
I need v3i PC suit can any buddy help me
Thank U
zeeshan
SOURCE: Unlock code on Motorola E815
By default the lock code on CDMA phones is the last 4 digits of the phone number so if you number was
555-555-0909
your lock code will be 0909 unless other wise changed, other than that the only way to get the code is trial and error.
SOURCE: bluetooth from lg 290cm
Straight Talk phones can only send and recieve items via bluetooth to other Straight Talk customers
SOURCE: FSK Voicemail Indicator not working
When you press the voicemail button on your phone it is retrieving messages stored internally in your phone. Verizons Voicemail is a seperate entity where the message reside on the server. If you do not want to use the Verizon Voicemail, simply call the business office and ask them to remove voicemail completely from the account. That way your phones internal answerming machine whille then catch all the voicemails and you can go back to using your voicemail button to listen to them. Hope that helps you and everyone else out.
Tony T.
