I am a beginner in computers, notebooks and the more so in the utilyakh and the programs standing on them. My friend from the Czech Republic sent me the old photo edited by someone in the .pdf format and to my deepest disappointment my AcrobatReader could not open, having written such error. An error when opening this document. The file is damaged and can't be regenerated. Read to me, please, as I need to reanimate this file to see this image.
Hi there! You can try the versatile app that can open PDF files easily which the ApowerPDF. This tool has everything you need in a PDF tool. Here you can see the full details of the tool. User Guide for Using ApowerPDF
SOURCE: Nero Vision Express 3.1.0.25
same problem, did a lot of research, no fix found, problem with nero dropping frames and not recovering. xvid codec not the issue, many people have the same problem with nero vision. bummer :(
SOURCE: i have a hand written documents which is scanned
No and here's why... Java is a programming language; its purpose is to be used to create programs that do useful things, but it is not equipped to do the complex analyses required to convert images to text. What you need is an OCR "image to text" conversion software application. Java is not such an application; it is a programming language meant to be used by programmers in a "platform independent context" (usually the World Wide Web). I suggest searching Google for what you need using these keyword strings: OCR image-to-text software. OCR stands for Optical Character Recognition.
Note that performing OCR on handwritten text is particularly difficult because it is so non-uniform (irregular). Here is a link that may be helpful in your quest for what is on its face at least by the way you asked, a very difficult process: http://www.softpedia.com/get/Office-tools/Other-Office-Tools/OCR-Image-to-Text-Conversion-Tool.shtml.
As one of my best programming professors (who taught me Java) used to say, "Yes, anything is possible in creating a computer program, but only if you have enough what? Skills, money and time to get the job done! Don't forget: time is money, so you know, don't bite off more than you can chew."
SOURCE: cannot open documents (.txt, .doc, .pdf)
try and update the firmware to the latest version for your country or network. you'll find a tutorial on the internet for upgrading. good luck
SOURCE: scan document as pdf on a Photo 926
open adobe acrobat..not reader, has no ability to create pdf's, and go to file, create pdf, from scanner
Don't forget to rank the advice!
http://www.aa1consulting.com
SOURCE: Cannot open any word documents, pdfs, photos etc.
Hi angela_sing
You can open your word documents, but not the ones sent by others, and you say you could open them before.
Well, I think the person(s) who sent the word documents before have upgraded to Word 2007. An earlier version will have difficulty in reading newer versions, so requires conversion. First of all, please check with the people who send you the word documents before you reinstall the O/S
Regarding photos, normally you would click on them and they open. But if a photo does not open in this manner, try the following:
Rifht click on the name of the file - you get a popup menu - instead of clicking on OPEN, you click on the OPEN WITH, Now a list of programs will appear which may be able to open your photo. Try each one of them, am pretty sure you will be lucky.
The same method can be used for your Word file as well.
Wish you all luck.
If this solution help you, please give a rating.
luciana44
