SOURCE: Can I use an Apple M7649 Studio Display with a MacBook Pro
Do you have the black unibody Macbook Pro that was just released, or the silver model?
Since the display is DVI, it will directly hook up to the silver model.
If you have the new model, you need a mini DVI to DVI adapter.
SOURCE: Mac Book Pro forgetting Wi Fi settings
yep! Go to the Systems Preferences window and select NETWORK.. then select Airport and the advanced button... you can drag your networks to the order you prefer and then check the appropriate box at the bottom of the list to keep your log in ... that should do it!
SOURCE: Reliance NetConnect
I
also purchased CDMA 1x but i have good speed. change modem setting put
"DNS" 8.8.8.8 & "Alternate DNS" 8.8.4.4 and type in "Static Ip
address" 8.8.8.8.now connect internet check speed.it's not high speed
we are satisfied.bye.
SOURCE: MX310 - Wireless network printer used on an Apple Airport Extreme
Here's what worked for me: I had everything set with my wireless network which included an Airport Extreme base station and two Airport Express units to extend range. I still couldn't plug and play with my printer. 1. You have to plug your printer into the Airport Express, turn it on, then select a document to print from your computer. 2. Select print from the pulldown menu (or select 'command P' on the keyboard). 3. When the print dialog window appears, go to the "Printer:" selection bar near the top of the window and select "print & fax preferences..." 4. This opens a new window, "print & fax." Near the bottom left of this window just below an icon list of your printers are a "+" button and a "-" button right next to each other. 5. Click "+". Yet another window opens which will reveal a list with your printer on it. 6. If you don't see your printer, click the "default" icon in the top left hand corner of the new window. 7. Select your printer, then click "add" on the bottom right hand corner of the window. The window will close automatically and return you to the "print & fax" window. 8. You should now see your printer in the list. You may say, "My printer was already in the list," but that's not good enough. The process you just went through enabled the computer to detect it on your network. You may want to use the "-" button to remove any previously listed printers from the list in the "print & fax" window. 9. Now you should be able to close the "print & fax" window and get some wireless printing done.
