SOURCE: panasonic cf-w5 with bios password,i
there is usually a jumper on the motherboard that will clear that. If you can't find it remove the motherboard button cell battery. If this is to hard try spotmau.com
SOURCE: bios password for panasonic toughbook cf 71
just clear the bios, by removing the jumper and put in its place again
SOURCE: Locked out and I forget the password!
If you can reach the motherboard you will find a round button cell. remove it for a few minutes and replace it again. the password would have been undone. Do not use passwords as one tends to forget them sooner or later. Or have one, if you must, that you can remember easily.
SOURCE: forgotten bios password
Remove CMOS battery for 3 minutes and get it back together. it shall be removed
SOURCE: panasonic toughbook cf-52 has bios
Welcome to Fixya
Bios password cannot be removed by just reseating the cmos battery. You might need to short the board to reset the bios password. Please take not that this is a critical job you need technical expertise in doing this.
Follow these steps:
Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
