SOURCE: water coming from bottom of machine
If this only happens when the machine is filling the hose leading to the top of the tub may be leaking. Before it fills this hose is disconnected from the water supply by a closed solenoid valve. There are two valves which feed into a common hose that comes up to the top of the tub where the water runs into the tub. The leak does not happen after the tub fills because all the water leaks out and no new water runs in. These hoses are usually very small and very inexpensive and held on with clamps. They can usually be replaced by removing a small panel near the hose attachment location.
SOURCE: Frigidaire Side-By-Side Refrigerator Leaks Water on Floor
I don't have the same refrigerator, but had a similar issue with a GE. Melt the ice at the bottom of the freezer. I think the water comes from the auto defrost feature. There should be a hole at the back bottom of the freezer that water would go into, and run to an evaporator pan under the refrigerator. The tube may be blocked that allows this water to drain, so it is backing up in the bottom of the freezer, and overflowing through the front bottom of the freezer to your floor.
SOURCE: White-Westinghouse washer will spin but water will not spin out
no its a remote electric pump,no belt.its ither blocked or fail.cut power,pop top remove frount cover an you will see pump.white or tan.remove hoses[watch out 4 water and check 4 blockage
SOURCE: some times water flowing from bottom side of the fridge
There should be a drain pan directly below the icebox which needs to be emptied from time to time. Some units have a drainpipe connected at the back, if yours has one, it may have become blocked.
SOURCE: Moldy taste from Whirlpool side by side
The problem can still be in your lines, or in the dispenser itself. If you run hot water with a little bit of vinegar in the lines and let it sit for about 30 minutes and then flush the whole system this should take care of your problem
