SOURCE: I have a 1976 75 hp 2 stroke evinrude that is overheating.
In the bottom of the engine is a rubber impeller/water pump. It is in the housing above the prop, not hard to change. Basic tools a six pack and about an hour. The part will cost you about $20, and you can order it from NAPA parts store. They will be about 50% less than a boat shop. Good Luck
SOURCE: 35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Testimonial: "Hi, thank you very much for your help, I will strip the carb down and have a look. Once again, many thanks, I am very greatful"
SOURCE: clone honda 6.5HP engine
hi
valve clearance(cold0
intake 0.005to0.007inch
exhaust0.007to0.009inch
byesavumihai71
SOURCE: oil weight to use for 1989 evinrude 2 stroke 90 hp
The oil is mixed with the gas, just buy 2 cycle engine oil and follow ratio mixture
SOURCE: power valve position and installation for yz 125
The proper adjustment is achieved when the notch in the actuator lines up with the pin hole in the cylinder casting.
My sensor was going off when I let the motor run in just a few minutes. The thermostat and water pump was fine. Checked the water pressure valve and thought it might be bad. Ordered a new one
