SOURCE: Removing the crown
The video i want to see you,is using older kind of watch,screwing before he can pull the crown ,the new model watches now like your Tag Heuer is pushing, use a needle to push, while pushing the stem lock you pull the crown .That's why ill tell you in advance so you aware.I know because i'm a watch technician working in rolex before...
remove the crown
if i helped,please,click FOR RATING .It is the only way i get paid for my works also,please consider leaving feedback..
Regards,
VOTIT
SOURCE: Timex Expedition watch beeping continuously please solve
Try to get solution here:
http://www.timex.com/gp/node/n/255235011/190-2521384-6105829?ie=UTF8&timexBrand=core
Rate, please.
SOURCE: need instruction manual for Timex 1440 sports
I have this watch, it think its the same one, the manual on the website didnt work for me either :D
okay
To change the Alarm
Hold mode whilst on the time section.
then start/stop changes between hour and minute, adjust changes the number.
To get off that press mode again.
To change the actual Time
Go on to the stopwatch section
Hold Mode, if it shows you the alarm press mode to change to time. The seconds should be flashing, press start/stop to change between hour minute second date, and adjust changed the number.
I really hope that helped even if its a month late :D
Testimonial: "I've had several Timex watches and this one is impossible! Thanks for the help."
SOURCE: How do I remove the crown/stem.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder.
Testimonial: "thanks"
SOURCE: I bought a Raymond Weil watch at watchmaxx.com,
They selling refurbished watches! Be careful!I got problem with Watchmaxx also,the watch was clearly refurbished!Costumer service is not helping at all. My 3000$ watch had scratches and dust leftover from buffing!!!!!!!
