SOURCE: We have a Canon IR400S with the following error
The error message means that the Fuser web has a problem. This is the part that cleans the upper fuser roller on the copier. It's located inside the left door of the copier and more than likely requires a copier technician to replace it. Fuser webs(belts) gradually get consumed after about 100,000 prints. The other possibility is that you may have had a brown-out or some other kind of power fluctuation in your area and the error just needs to be reset in service mode, but I'd check the first solution 1st, the part is cheap $25-$50.
SOURCE: I have a error message on my Canon Image Runner
This is the fixing motor fault error.
You will need to replace either the fixing motor, the DC controller or the main Power supply PCB.
There is no reset for this fault.
SOURCE: Getting 6C10 error on my
turn off the printer.
Press and hold the resume button and click and hold the power button.
While continuing to hold the power button, release the resume button.
Still holding the power button, click the resume button 2 more times.
Release both buttons.
Click the resume button 4 more times.
Turn the power off then on.
SOURCE: the error 6A81 comes up
This is a purge unit error. There maybe something jamming the purge unit or just a absorber out of place which is picking up on the carriage preventing it from moving correctly. if you can move the carriage away from the purge (its where the printhead/carriage parks its self on the right side of the machine) with no resistance then you can shine a torch into the machine and look at the purge unit. there maybe crumpled paper jammed in the purge. If all looks well then the purge may need replacing. Lastly the wiper on the purge may have stuck. It slides back and forth and they have been known to stick. just push it with a long screwdriver to see it it moves.
Good luck
SOURCE: Every time I try to print my canon pixma MG5220
You need replace the ink absorber .
Or you can disassembly the printer and clean with running water tha ink abserber.
Is located below the cartrigde
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
