C
Chris Shaw Posted on Mar 26, 2018
Where can I get a user manual for a Braun Paximat Multimag SC663 slide projector
The motor struggles to turn the fan on my Braun Paximat N24 slide projector. Any ideas please?
My guess is the sleeve bearings in the fan motor need oil. I use teflon based oil.
Braun Paximat Multimag 250 AF Hand operated slide change works but has resistance. When using the remote control the side can only be part viewed and needs assistance by hand operating. I believe there...
If you are in the USA send it to Braun service at:
HP Marketing Corp. PO Box 715 16 Chapin Rd. Unit 908 Pine Brook, NJ 07058 800-735-4373
Otherwise check the factory web site for Braun service in your area. www.braunphototechnik.com
I also need a Braun Paximat Lamp bulb 58.8394AMX
What is the description of the lamp? Braun's current catalog numbers for lamps are 80231 for the 150W 24V and 80232 for the 250W 24V. If you need a different lamp you should bring the old lamp to a camera store and let them look it up from the bulb manufacturers.
I need bulb for braun paximat electric projector
You should take the old lamp to a camera store and see if they can find a substitute.
Hello, I recently acquired a 'Braun Paximat N 12' all seems to work ok but no slide tray. Any idea where I can get one?
Gepe Universal 50 Straight tray should work. It might even use the Braun CS Compact trays but the Gepe are more common.
2helpful
2answers
2answers
Top Braun Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Braun Office Equipment and Supply Expert? Answer questions, earn points and help others
