SOURCE: my consew 226R-1
Hello lilliang ,
You can check out the procedure in ur manual itself in detail!!
SOURCE: My consew 226R-1 is out of time, can anyone help??
http://consew.marginspluslive.com/images/products/PARTSBO/224-224r1-225-226r1instr.pdf
THIS SITE HAS A MENUAL YOU CAN PRINT
I HOPE THIS IS HELPFUL
MONI
SOURCE: consew industial machine keeps skipping large areas
remove the front cover around the needle area also you may have to just strip the machine down!! to the hard ware with the bobbin door removed rotate by hand the crank till the neddle goes down to the bobbin area and losen the screws on the bell part of the crank and adjust it till
the needle is dead center and all the way into the bobbin then tighten and reassemble
