You need to get a proper bracket for the TV. Some TV units use a vesa mount but the Techwood uses a much larger mount. If you look in the manual for the TV, it will call out the bracket size in mm. You can order and go from there. Fairly simply process.
You need a VESA mounting plate.
The VESA Standard defines mounting interfaces, hole patterns and associated cable/power supply locations for LCD/TFT monitors.
The monitor you have has a 75mm x 75mm hole pattern as per the spec sheet below:
http://www.nec-display-solutions.co.uk/coremedia/download/62980/LCD1560VM-Datasheet-english.pdf
There are many types of bracket depending whether you want the panel flat on the wall or to be able to swivel it. You can see some example on the page below:
http://www.rs100.co.uk/product_info.php?cPath=30_55&products_id=580&osCsid=15qvrvji4vn4uk49pcidd38q83
You need to search your location for a supplier.
Please update the question & let us know if the information given was useful to you - Good Luck!
