There is no way to reset, but they are very insecure and can be opened with the bounce method, banging the top with a rubber mallet whilst turning the lock dial, or by using a rare earth puck magnet in a sock! Or just call a locksmith.
Replacements can be ordered online from some companies by taking the code from the barrel and having it cut, a lot of online cutters have databases with it all and you just send them the code
Call the number above, give them your model #, the serial number
(located on the right side of the safe next to the model number), and
your key code. They will provide you with the combination to your safe. your combination number will be provided to you immediately.
Also, you can try
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial
CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door
open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number
FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO
(2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE
(1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
