Question about Kirby Vacuums
Where is reset button for kirby amazing mirrors
Kirby G5 self propel problem
There is an adjustment for the transmission and it is wrong. It could also be worn. The Kirby has an amazing warranty. See if you can get it serviced for free.
Mar 22, 2013 | Kirby G5 Bagged Upright Vacuum
Tip
SMELLY KIRBY BAG???? HERE'S WHAT TO DO!!!!
I have written a guide to help with the cloth bag odor problem. View it simply by clicking this link....YOU'LL BE AMAZED AT HOW EASY IT IS!!
http://reviews.ebay.com/DEODORIZING-CLEANING-THE-KIRBY-VACUUM-OUTER-CLOTH-BAG_W0QQugidZ10000000003719865
HAPPY VACUUMING!! :0)
Marci
on Feb 06, 2008 | Kirby G4 Bagged Upright Vacuum
Reset button for Kirby vacuum
kirbys do not have a reset botton ?
Nov 05, 2012 | Kirby Vacuums
Is there a reset button for Kirby G6?
One set button on your Kirby. Remove the head to check for blockage in the fan.
Aug 14, 2012 | Kirby G6 Bagged Upright Vacuum
Kirby G4 plugged in won't come on? Is there a reset button and where is it?
There is no reset on a Kirby. Remember that the motor will not run unless the bag assembly and vacuum head (or hose) are fully in place. If this is not the problem, the most likely causes are either a bad cord, a bad switch, or a worn or stuck carbon brush in the motor.
Apr 16, 2011 | Kirby G4 Bagged Upright Vacuum
Is there a motor reset button? power light lites up but no motor
Troubleshooting tips are found on page 51 of the G6 manual. This applies to most Kirby models.
This manual can be found at the below link.
http://ubermanuals.com/search/contentsearch/kirby
Mar 13, 2011 | Kirby G4 Bagged Upright Vacuum
Does the kirby G5 have a reset button? If so,
No reset button. It sounds like you might have one of several possible problems. Some ideas I have that you could try yourself would be to check the lockout switches: there is one behind the head nozzle, maybe the nozzle is on crooked, if so, maybe not engaging the safety switch, the other lock-out is located where the bag screws on, unlock the bag and re lock it to ensure proper fit. Otherwise, take it to the shop because it could be the motor, the cord, the switch. Hope this helped ya. Let me know. Thanks, Rene (the Vacuum Doctor)
Nov 11, 2009 | Kirby G5 Bagged Upright Vacuum
No power
I'm not familiar with Kirby vacuums, but press your reset button a few times (if you have one). If that does not work, then it is most likely the switch. For a rough estimate of the switch or parts for your vacuum, please refer to Sears Parts website and have your model number ready.
Sears website: http://www3.sears.com
Mar 07, 2008 | Kirby G5 Bagged Upright Vacuum
ALUMINUM ON KIRBY VACUUM
You can take it to the nearest Kirby dealer to get it buffed out for about $25. Most of us use buffing pads on a bench grinder. The polishing compound can be found at Lowes or Home depot in the tools area next to the buffing pads. Three compounds are usually used. First a cutter, then a cleaner, then a finish polishing compound. You can get by pretty good with just the last two. Make sure you clean the pads between the different compounds. You can do this by gently placing a flathead screwdriver in to the buffing pad to clean it. Wear safety glass and an old shirt.
Feb 24, 2008 | Kirby G5 Bagged Upright Vacuum
Power problem
Hi, Try logging your post on the Kirby Trading Forum at Kirbydirect.co.uk - you'll be sure to get a reply. John
Aug 03, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Vacuums Logo
75 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Chris Nomland
Chris Nomland
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
